MEXICOWANDERER
Sep 04, 2017Explorer
Something COMMON to both problems is chassis negative THE GROUND.
Truck wire to socket. Check wire where it hooks to frame as well
Truck socket.
Umbilical cord to trailer. Does it have a pinch mark in it?
Where umbilical connects to trailer chassis wires.
I don't believe in miracles and the chances of 2 errors happening simultaneously in two circuits is like 10,000 times less likely than a bad ground connection.
Print the list of "The Usual Suspects" above or even the entire response and take the rig to a DIFFERENT repair service.
Truck socket.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
