dougrainer
Sep 04, 2017Nomad
1. WHY he would pull the wheel assblys apart shows complete lack of knowledge. The fact you had BOTH running lights and brakes issues points to one thing---The 7 way connection at your Truck.
2. I would not think the 4x4 junction box on the Jayco trailer(where all the tow plug wires go to) would be an issue as I would hope the Tech checked that
3. The usual cause of your type problem is a rusted trailer 7 way end or your truck 7 way has a problem.
4. An easy check is to connect your trailer to a friends truck and test drive. If the problem goes away your truck is the problem. If it stays then check the Trailer 7 way and the wiring to that 4x4 junction box which will be where the A frame is welded to the front trailer on the outside. Doug
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
