ernie1
Feb 24, 2020Explorer II
I totally agree with mchero.You've determined that it's the cold side of the faucet that's leaking. Have you put a wrench or pliers to the fittings? Why does the fitting only leak sometimes and not others? You've already figured out that this happens when the water heater is running so that means that there's more pressure in the system and the pressure can vary quite a bit and the leak will only get worse with time and not better nor the same. After trying the wrench or pliers on the fitting with no luck, look long and hard at the fitting itself for cracks or splits. If this is not the problem, consider changing the faucet itself and get on with life. Quit wondering why and how this is happening. Most bathroom faucets are a pos plastic and will not last very long anyway.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
