alfredmay
Feb 25, 2020Explorer
The check valve will not allow water to leave the RV and enter the public water system. Therefore when the pressure in the RV exceeds the incoming water pressure the valve closes and the water pressure in your RV goes higher and higher as the water is heated. The cold and hot water systems are connected so the weakest link is your cold water fitting and it begins to drip.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
