fj12ryder
Dec 23, 2018Explorer III
If you're not charging your batteries it's unlikely your DC output from the converter is fine. It's more likely that you're running off the battery and running the battery down. Easy way to check would be to disconnect the battery and see if you still have 12V power. I'll bet you won't.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
