rjsurferExplorerDec 23, 2018Internal fuse for the WFCO 55 Amp Converter?I just noticed that I'm not charging the batteries when hooked up to the power pole. The batteries are down to 12.0v, they should be showing at least 13.4v. The 12 volt DC output is fine, all the l...Show More
enblethenNomadDec 23, 2018Yes, it has reverse polarity fuses. Verify that there is 120 volts to the unit.WF-9855
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
Related ContentFuse panel locateReplacing Microwave's internal fuseNo 12 Volt without converterInternational80 amp converter and eu2000i
