I just noticed that I'm not charging the batteries when hooked up to the power pole. The batteries are down to 12.0v, they should be showing at least 13.4v. The 12 volt DC output is fine, all the l...
I would suggest this unit. PD9260 I would do more testing before putting out the money. Have you reset the 120 volt circuit breakers? Verify power to the converter then check for output. Finish your trip and then do it at home when rested!
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
