MEXICOWANDERER
Dec 28, 2018Explorer
5-amps. Probably one of the handiest accessories I own.
Use with a disconnected secondary leg of the charger/inverter/any load.
Take the breaker, and make two foot-long pigtails. Use .250" push-on fully insulated terminals. Other end use two good quality alligator clips. I like to put the very common alligator clip rubber shields over the clips.
Energize the converter.
Keep one hand handy to disconnect your temporary power to the converter, You can yank on this circuit breaker to disconnect one or both alligator clips but you must then follow through and safely disconnect the other clip as it might be live and angry enough to kill you if you touch the exposed alligator clip. I yank the wall plug powering the circuit breaker.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
