road-runner
Dec 28, 2018Explorer III
time2roll wrote:Ideas are ok. This was presented as fact:
I think the idea is that the converter could still be damaged even if the fuses open.
Are you feeling lucky? I don't recommend testing it.
IF the reverse polarity fuses blow, the Converter will be bad. They do NOT protect from damaging the Converter from reverse polarity.
Of course it's true that the fuses don't protect the converter, but rather the RP diode protects the converter and the fuses protect the RP diode. Maybe the converter does get fried and the RP protection is there just to prevent a wiring meltdown or fire. I've always assumed that the converter wouldn't be damaged, and the manual says "This feature prevents permanent damage to the converter from an incorrect battery connection". With this "converter will be bad" statement going against the manual I'd sure like to see a confirmation that it's a real life fact.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
