Belgique's avatar
Belgique
Inverter - Auto Transfer
The Xantrex XS-400 you folks helped me install back in '08 may be dead. (Any ideas on who can fix them or would it cost more than it is worth?)
The XS-400 is hard wired and I love the auto transfer since it keeps the DirecTV box from re-booting. The circuit fed by the XS-400 just has light loads, e.g., the TV and lap tops.
I see in searches here that Xantrex sells an in-line transfer switch. If I were to buy an inverter that doesn't have the auto transfer function built in, could this external switch be used in my hard wired setup? I can't tell from the literature. And to confirm...this is an auto switch?
Thanks in advance.
  • Michelle.S wrote:
    How about a small UPS for the DirecTV Rcvr?? Been thinking of going that route ourselves as the DRV takes close to 10 minutes to reboot and rebuild it's program list.
    Interesting thought. But I also use the TV/receiver on batteries. So it would have to be a rather large UPS or plug it into my main inverter which runs off of the batteries.
    I'm still thinking a dedicated inverter for the TV/receiver...
  • CA Traveler wrote:
    My Magnum uses relays to transfer and the DTV receiver reboots. I'm considering adding a small inverter for just the receiver and TV to eliminate that problem. ie They would always be running on the battery but when I have AC the charger will maintain the battery.
    I had the same problem, and that's exactly what I did, 400 watt inv powers the whole intertainment center, and an outside receptical in a basement comp. No more ATS's for me,.......they can be a real PITA !
  • Hi,
    My vote would go to a quality sine wave inverter running the entertainment system 24/7 using double conversion. That saves the cost of the transfer switch, and when on shore power the inverter won't make a lot of difference to the battery charging (slows it down a bit).
    Go Power, Samlex, and Morningstar all make a quality psw that you could use. I give a tiny advantage to the Morningstar as it has no cooling fan and so is 100% silent in its operation.
    Mornighstar 300 watt
  • Belgique wrote:
    (dedicated inverter) What a great idea! It is the only thing that "needs" to be kept alive.
    Either that, or get a bigger inverter and run your coach on that all the time.. with the exception being the air con.
    :S What a great idea! It is the only thing that "needs" to be kept alive.
  • How about a small UPS for the DirecTV Rcvr?? Been thinking of going that route ourselves as the DRV takes close to 10 minutes to reboot and rebuild it's program list.
  • If spending money today I would get the GoPower 300w sine wave inverter and that Xantrex ATS.
    Easiest would be to replace XS-400 with same.
  • My Magnum uses relays to transfer and the DTV receiver reboots. I'm considering adding a small inverter for just the receiver and TV to eliminate that problem. ie They would always be running on the battery but when I have AC the charger will maintain the battery.
  • Hi,
    Yes, it is an external autotransfer switch rated to 15 amps. 15 amp auto transfer
    Whether such a switch will "hold" the memory in your devices depends on the speed at which it switches over.
    The inverter you have is likely a throw away at this point, unless you can find a local repair shop that will "take it on".
    For light loads I'd suggest looking at the Morningstar 300 watt inverter. It is expensive but appears to be bullet proof.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
