3_tons
Aug 13, 2021Explorer III
BFRD22 wrote:
Update
1st thanks for the replies. I found that if I put a load on the generator first (Im using at 10amp battery charger, was going to try a trouble light next time out) then plug in the RV shore line every thing works as it should. Guess the extra load is just to clean up the signal to the Xantrex.
Thanks Again
Thanks for the important followup as in a similar fashion, it was ONLY the ‘pass-thru’ inverter that had prevented the ability of my Honda 2200 from operating the Coleman air cond while in the Eco-mode….My solution was to simply add a new ‘corded’ ATS switch between the Coleman and the inverter, with the Honda as the Dominate power source…
3 tons
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
