tworExplorerFeb 13, 2020inverter adviceReplacing a Xantrex 400W with similar size inverter. Recommended brand to get? I have 4 Trojans for house batteries.
LwiddisNavigatorFeb 13, 2020Doesn’t inverter efficiency peak when the unit is operating close to its max? If that’s true, buying a larger inverter than necessary wastes power. See this article and chart:https://www.solarquotes.com.au/blog/two-reasons-you-must-look-at-efficiency-curves-when-choosing-your-solar-inverter/
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentInverter Bad?Inverter installAdvice on inverter sizeSolar & Inverter starting point adviceInverter/power advice
