Jetta03's avatar
Jetta03
Inverter and battery fumes
So last year I upgraded my battery box on the tongue to a diamond plate box containing my 2 grp 27 12 volt batteries. The box was big enough to install the batteries and to build a smaller sealed off compartment for a 1000 watt pure sine inverter. The battery compartment and the inverter compartment are separated and sealed from one another, and both are vented separately to the outside, the inverter for cooling and the batteries for ventilation of fumes.
The 1000watt inverter just died on our last trip. It's a cheap version from our local Canadian Tire store and they replaced it free under warranty. My question is could this failure be due to issues from battery fumes even though I've separated the compartments?
The failed inverter had bits shaking around inside it so I'm guessing this was a quality related issue, but I'd like to avoid it happening again if possible :)
Thx
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
