SPRING_STREET
Jan 20, 2014Explorer
Yes GBaxter you are correct. I was talking about the inverter. I have the Magnum Energy System on my RV which has the Charge and the inverter on the same panel. I always leave the charger on but was wondering if i needed to leave the inverter on when i am on shore power, or if it would be of any benefit it it was left on.. Usually the only time I turn it off is if I am dry camping and leave the coach for a long time to save on battery drain. . I do have it set so the genny will turn on automatically if the amps drop below a certain point !! Being that the RV is winterized and hooked to shore power my question was leave the inverter on or off ?? or does it make a difference. Thanks for the responses! Dave
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
