beemerphile1's avatar
beemerphile1
Inverter and/or electric troubleshooting help needed
2001 Holiday Rambler Ambassador 37' DP motorhome
2000 watt Nature Power PSW Inverter/charger (not OEM)
Residential refrigerator
This is a friends unit, they bought it in the winter and did not thoroughly check it out. They have now sold their house and moved into the MH.
Here is the story I got;
They parked at friend's home and plugged into 50a service. The refrigerator and microwave did not work. The inverter started getting very hot and the readout was flashing error codes and various craziness.
They called a mobile service tech, for $213 he told them the inverter/charger was bad and he couldn't help them. He separated the positive battery cable from the inverter. He left them disconnected from shore power and essentially dead in the water.
The owner claims the refrigerator works on generator but not on shore power.
Here is where I started;
*good 50a shore power verified at receptacle
*good 50a 240v at the main breaker in the MH breaker panel
*with shore power on but battery disconnected the inverter readings go crazy
*batteries are nearly dead at 11.8v
*verified that the inverter receptacles are dead on shore power
I found two receptacles behind refrigerator, one inverter and one shore power. By moving the plug to shore power the refrigerator started operating and made me their hero.
I did NOT reconnect battery power to the inverter.
I did turn off the inverter breaker in the panel.
The thing that really puzzles me is that the owner stated the refrigerator worked on generator power. If true, the inverter passes power on generator but not shore power. That does not make sense to me. I did not witness this but have to take the owner's word for it.
I instructed the owner to get a portable battery charger and put it on the house batteries.
I have owned many trailers with converters. I have installed stand alone inverters. I have also installed residential and commercial electric but none of that prepared me to work on inverter/chargers so I'm a bit over my head.
What can I troubleshoot further to narrow down what is wrong?
  • The OP stated that it is plugged into 220VAC 50A. There is the problem, plane and simple. He does not need to see or know anything else. The OPs friend fried everything in his RV because of a dumb newby mistake.
  • inverter is off NO charge or pass thru power with breaker OFF
    fridge is working from NON-inverter outlet
    fridge supposely worked on the inverter outlet, with generator on (before inverter failure) and from generator (no way to verify this) (was this with them at home or at time of sale, seller could have been hiding the defect inverter)?
    inverter obviously NOT whole house ?
    i wonder is there a sub-panel
    a breaker in the main panel feeding the inverter, feeding the sub panel
  • Can you get the exact model number of the inverter?
    Does the rig have a converter as well?
    Here is a manual for what seems to be the,manual
    Yes, verify what voltage is at shore power connection. Should be 120/240.
  • My guess they did NOT plug into a 50A 120VAC outlet, but a 50A 220VAC dryer outlet. If they did they need to be prepared to spend lots of cash fixing the mistake. Happens all the time, but its going to cost to make things right. Assume most anything electrical will be toast.
  • Friends shouldn’t help friends with problems on their newly purchased, OLD and uninspected before purchase MH or they won’t be friends anymore.
    “I did not witness this but have to take the owner's word for it.” The seller or the buyer?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
