tlaffourtit's avatar
Sep 08, 2014
inverter, batteries,converter,tranfer switch, etc.
We own a 2015 thor ace 30.2 motor home. We are installing a 5000w pure sine wave inverter using 870ah batteries(12v). We are using 12v batteries because I was given them for free and they are deep cell batteries and are new. will also be installing 790w solar panels. we are trying to find out if this is enough power for the unit and would like to verify the manner we are installing them. I need to know how many amps the present converter/charger charges at, if I can change out the transfer switch to a 3 way to include the inverter with the generator and shore power(assuming there is only a 2 way transfer switch installed now), and if I use an inline transfer relay between the inverter and converter will this work correctly.( so the unit does not try and charge the batteries while the inverter is in use) since I never attempted this before I am sure I have most of this wrong. ideas would be helpful
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
