tlaffourtit
Sep 08, 2014Nomad
smkettner wrote:
Is that 8 batteries in parallel? Going to need 600 amp bus bars to connect.
Just need a 50 amp transfer switch. (50a RV assumed) Insert between existing TS and the main panel. Converter needs to be moved to get power from before the added switch.
I have seen a 3-way transfer switch but not at this power level.
This inverter? Get a copy of the installation manual and read it at least twice before you buy.
yes I am using 8 batteries, and it is 30 amp service. I did see a 3 way transfer switch for 30 amps. would this work, and if so would it just be a straight replacement with the old one except adding the inverter circuit?
