shooted
Sep 08, 2014Explorer
tlaffourtitkway wrote:2oldman wrote:manual does not have a wire size. i will run 2 #1 cables. it does have 2 battery and return post plus a chassis ground.tlaffourtitkway wrote:What does the manual say? Where did you pick up this inverter?
I don't know the size cable needed for 12v
To make use of the full available 5000 watts, larger cables would be required. My quick math indicates 400+ amps and would require 4/0 wire. Is 5000 watts necessary?
