tlaffourtit
Sep 08, 2014Nomad
smkettner wrote:
The 3-way would replace the existing transfer switch. It would have 3 inputs, 1 output.
Or a standard 30 amp switch is fine. Place it between the existing and the main breaker panel. Go Power has a 30 amp switch that breaks out power for the converter to avoid the charge loop.
Yes you need 4/0 wire to the battery. thank you for your help. ill complete this first before continuing with the solar. will consider dumping the 5k inverter for another model.
