shooted
Sep 08, 2014Explorer
smkettner wrote:. Based on the specifications this unit should be capable of running the air conditioner. The quality and reliability of this brand is the unknown. I would suggest some bench testing prior to incorporation into the distribution of your rv.tlaffourtitkway wrote:The RV is only 30 amps, 3600 watts. 5,000 watts will run everything same as utility power. Just a matter of how long the battery will hold up.dan-nickie wrote:if it can, it will. but I am doubting there will be enough watts to start the unit.
Just curious if the air conditioner will run off this inverter?
