mena661
Sep 08, 2014Explorer
Do you have a built in generator? If so, you'll need an additional transfer switch (TS). You can pull the generator input to your existing TS and use that as the input for your new TS. One output of your new TS goes to the existing input of the OEM TS. The other output goes to your breaker panel. So when you're boondocking, you're either on inverter or generator. It APPEARS on that link of the inverter that there might be a "hard wire" option on the AC side. That will allow full use of the inverter without plugging stuff in the front and being limited to that receptacles current rating.
