tlaffourtit
Sep 10, 2014Nomad
2oldman wrote:tlaffourtit wrote:When you make replies like this, I begin to wonder if this is really the project for you.
im not sure what size ac unit you have but mine is a 1550btu and I could be wrong but I believe it starts up at 19 amps and runs at 13 amps. I don't know why yours needs 95 amps to run.
MEX is talking about amps from the battery side, not the 120v side. And your air is probably 15000btu, not 1550.
you are correct I left out a 0 15000btu is the correct number. as far as the ac or dc side goes i never said i knew what i was doing. if i did why would i ask for help. So please keep your negative comments to yourself. thank you
you can sit back and not do. i rather listen, read, and try to accomplish.
