tlaffourtit
Sep 10, 2014Nomad
shooted wrote:
If installing a 30 amp transfer switch, you can size the inverter cable and fuse accordingly since you will not be able to make full use of the inverter capacity. Have I missed something?
no that's it i think. the inverter is rated at 5000w / max 10000w but from what you guys on this site and the u-tube videos the inverter will never hold 5000w. so i am going to use a smaller fuse between the batteries and inverter( on the hot side of the batteries a 500 amp fuse) and treat it as a 3000w inverter. if i'm wrong with the fuse size please let me know. thanks
