RoyB
Apr 25, 2017Explorer III
I had to use a bonding plug on my 2KW Generator to keep my GFCI circuits from popping... I did what I found online being a plastic 120VAC receptacle plug with the GND and NEUTRAL contacts wired together as shown here... Worked fine plugged into the second receptacle socket while I was using the other socket for the load...
Google Images
Then later on I had a similar problem using my 1500WATT PSW Inverter feeding my Trailer 120VAC Power Distribution panel using the traler shore power cable so I plugged the BONDING PLUG into one of the empty sockets on the Power Inverter and got the same results...
Roy Ken
Google Images
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
