Dutch_12078
Apr 25, 2017Explorer III
RoyB wrote:
Then later on I had a similar problem using my 1500WATT PSW Inverter feeding my Trailer 120VAC Power Distribution panel using the traler shore power cable so I plugged the BONDING PLUG into one of the empty sockets on the Power Inverter and got the same results...
Roy Ken
As Bill wrote in his post, the Kisae bonds the neutral and ground ONLY when it's appropriate to do so when in service. When the RV is connected to shorepower, there should NOT be any onboard neutral/ground bonding.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
