KATOOM's avatar
KATOOM
Inverter capacity?
I try not to ask questions which have been repeatedly discussed but sometimes the right answer is hard to find with the search function.....
I am thinking of installing an inverter but am not sure of what size I will likely need to accomplish what I was wanting to do. All I would want it for is to possibly run the microwave for a few minutes if needed, the coffee maker in the morning, and the TV for 2-3 hours at most. Obviously not all at the same time though..... So with that said, what do you guys think? And I've also heard that pure sin wave inverters are the only ones to get.
  • The microwave is the highest amp draw, so will determine the minimum size inverter. Size the inverter so it will power the microwave on HIGH and still have a 20% reserve capacity. There should be a label on the microwave stating its power INPUT needs (not necessarily the same as output)
    Clearly, a sine wave inverter is better than a MSW. As to whether your particular appliances will run OK on MSW, I don't know.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
