treeofliberty
Apr 26, 2016Explorer
2oldman wrote:treeofliberty wrote:A bit. Remove shore power from the breaker box and connect to inverter input. Run inverter output to breaker box.
Is this nothing more than running 10AWG wire from the inverter into the fuse box, or is there something more complicated?
I didn't literally do what I said above.. I intercepted my shore cable where it enters the coach at a jct box.
If I may echo what you said another way, to see if I understand you correctly, you routed around the stock converter, essentially replacing it with your inverter/charger. Did I understand you correctly?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
