tulegit wrote:
What if I want more than one 15amp circuit to be powered by the inverter? I have outlets all over the toyhauler that we use to charge phones/tablets.
Very easy. It appears that the APS750 has a male plug for input power and then 2 female 15A receptacles correct?
I will add that you WILL NOT have a full 15A availability to all the outlets. On Inverter power you will have 8A to share and on shore power you will have about 12A to share.
Take a look at your AC breaker box.
You should have the following
30A Main breaker
20A A/C Breaker
15 or 20A Microwave Breaker
15A General
15A General
If it looks like that things will be fairly easy. Let me know, if it doesn't take a photo.
The only thing that might cause issues is where the fridge draws it's AC power from, but that's not any more of an issue that switching the fridge to "GAS" from "AUTO".
So take a peek at your panel and report back. This should be a fairly easy fix.
I also have an idea on how to keep the converter in the mix for faster charging while boon-docking, as it would take 5 hours at a full 20A output to get from 50-90, which won't happen.
