Just departed on cross country trip in used class c I just purchased. I have an older model Galaxy 2500 inverter but with no manual. When no shore power I can power it up fine and plug in either of 2 ...
I ASSUME it has 2 each 120VAC outlets. If nothing is plugged into the 2 outlets it isn't powering anything. If you want it to power some outlets you will need to wire it to do so. Know what you are doing before you attempt this.
What do you want to power with it?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
