JR51ExplorerAug 02, 2018Inverter HelpJust departed on cross country trip in used class c I just purchased. I have an older model Galaxy 2500 inverter but with no manual. When no shore power I can power it up fine and plug in either of 2 ...Show More
YC_1NomadAug 11, 2018I think I looked up the proper inverter but maybe not. If I am correct it sure does not look like it has a way to power outlets other than the ones on the unit, If you have something plugged into the front right now that may be a television.And if you have the ignition switch on there may be a relay shutting it off if the tv is mounted up front Sorry, if,ands, and buts.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
