JR51ExplorerAug 02, 2018Inverter HelpJust departed on cross country trip in used class c I just purchased. I have an older model Galaxy 2500 inverter but with no manual. When no shore power I can power it up fine and plug in either of 2 ...Show More
wa8yxmExplorer IIIAug 18, 2018Re turning off the conveter.. On your main circuit panel there should be a breaker marked CONV or CONVERTER.. that will do the job.Else you are going to need to add-a-switch.. Easy if you know how. not if you don't. HOW depends on the converter.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
