Just departed on cross country trip in used class c I just purchased. I have an older model Galaxy 2500 inverter but with no manual. When no shore power I can power it up fine and plug in either of 2 ...
something is confusing here, do you mean no power on the outlets or do you mean the inverter does not come on the inverter uses battery DC power, turning off a panel breaker should not turn off the inverter
are you shutting off the main breaker ? or are your outlets on the same breaker with the converter then you need to get somebody to change the wiring, so you either unplug the converter or flip a switch
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
