JR51's avatar
JR51
Inverter Help
Just departed on cross country trip in used class c I just purchased. I have an older model Galaxy 2500 inverter but with no manual. When no shore power I can power it up fine and plug in either of 2 outlets and they put out power. It has a wired plug in one of the outlets that goes to my electric connections, along with positive and negative connections from batteries. I assumed that when powered up it would supply power to all my outlets throughout the rv. Why is it not? I can do some basic troubleshooting myself if told what to look for but prefer not to open inverter unless there is an internal fuse involved in the problem. Thanks in advance to any and all suggestions
Happy Trails
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
  • it powers some outlets ? but not all ?
    that is normal, the outlets NOT powered, could also have your power charge converter on that ciruit
    if that was powered you would be in an endless power 'DRAIN LOOP'
    you can't use battery power to charge batteries
    even RV's that come from the factory with 'all outlets' on inverter
    have items like the charge converter, a/c, etc.. not thru the inverter
    addon install like you have almost always have only 'some' circuits powered
    usually TV, bedroom, bathroom , depending on where the converter is mounted and how it is wired, maybe a kitchen outlet
  • Totally normal for an inverter to NOT power all outlets.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
