time2roll wrote:
How is the inverter wired? How many batteries? What size 12v wire?
Does it just sit there and you have to plug in the main cord?
Otherwise you need to pull wire and install a transfer switch and remote if you want push button power.
Ok to post some pictures.
BTW my 300 watt inverter powers the outlets just fine. Dealer is full of it or does not understand electricity.
2 12 volt batteries, not sure how it's wired. Right now it's in my basement close to the batteries. To use it, I have to go outside the fifth wheel, open the basement, turn it on, plug on an extension cord and run it to what I want, clearly not useful. I was expecting to be able to plug into any outlet and use them after the install like they come from the factory.
