2001400ex wrote:
MrWizard wrote:
is your shore cord in or near the same basement location ?
yes ?
then step (1) is turn off the circuit breaker for your charge converter
step (2) put fridge on LP, put water heater on LP
step (3) use what ever adapter is needed and plug your shore cord into the inverter
turn on inverter
reverse process when you need the generator
BEFORE you start the generator
Step 1... Is that just a circuit breaker in the panel? I don't think I've seen one labeled that before.
My distribution panel didn't have a label either and I had to experiment to find the correct one.
