Bobbo
Mar 19, 2020Explorer III
SpeakEasy wrote:
"Local regulations my require a true neutral. In this case one of the AC output wires must be connected to the chassis, and the chassis must be connected to a reliable ground. Please note that a true neutral is needed to ensure correct operation of an earth leakage circuit breaker."
Not a problem. I like helping people solve problems. I like, even more, telling people they don't HAVE a problem.
In the quote from the manual, the phrase "one of the AC output wires must be connected to the chassis" is what I am calling "bonding". That phrase in the manual implies that it is perfectly fine to go ahead and bond the inverter if it makes you feel better. There will be no actual benefit from doing so, but your tester will show what you want it to. If you do this, just be sure you bond the NEUTRAL wire to the chassis, otherwise, your tester will show the outlet as reverse polarity.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
