SpeakEasy
Mar 19, 2020Explorer
Bobbo wrote:
In the quote from the manual, the phrase "one of the AC output wires must be connected to the chassis" is what I am calling "bonding". That phrase in the manual implies that it is perfectly fine to go ahead and bond the inverter if it makes you feel better. There will be no actual benefit from doing so, but your tester will show what you want it to. If you do this, just be sure you bond the NEUTRAL wire to the chassis, otherwise, your tester will show the outlet as reverse polarity.
Understood.
Thanks again.
-Speak
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
