MrWizard
Mar 19, 2020Moderator
No..NOT a concern
Tester show open ground, because neutral side of circuit is Not bonded to ground like utility power is, everything will work just fine, you would get the same tester response using a portable generator to power the RV
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
