Hi, I bought a Thor 3000watt inverter , so I can plug my whip from my rv into it and power up the camper, so I don't have to run my generator. Its a 2016 work and play 34WRS. I have a Yamaha 6300...
Why is the shore cord neutral connected to battery negative That is against wiring code
Only the ground should be attached to buss bar frame ground Neutral should not be grounded at all
Should only be attached to the "unbonded" neutral bar in the breaker panel
Is this an installed generator, or a portable generator, If installed, it was not installed correctly, if portable it should not be connected at all and has nothing to do with the problem , If it is unplugged
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
