shockoExplorerJun 02, 2017Inverter issuesHi, I bought a Thor 3000watt inverter , so I can plug my whip from my rv into it and power up the camper, so I don't have to run my generator. Its a 2016 work and play 34WRS. I have a Yamaha 6300...Show More
MrWizardModeratorJun 02, 2017the inverter displays a ground fault code ?or some little plug in tester, you stuck in an outlet ?is the inverter producing power, but a tester gives you this erroror is the inverter NOT producing powerhow did you wire in the invertershould be (2) wires direct to batteryand the inverter case ground goes to RV frame ground NOT to the battery
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
Related ContentInverter Bad?Inverter installTowing lights issue12 Volt Power IssueElectrical outlet issues
