shocko
Jun 02, 2017Explorer
Inverter issues
Hi, I bought a Thor 3000watt inverter , so I can plug my whip from my rv into it and power up the camper, so I don't have to run my generator. Its a 2016 work and play 34WRS. I have a Yamaha 6300...
MrWizard wrote:
the inverter displays a ground fault code ?
or some little plug in tester, you stuck in an outlet ?
is the inverter producing power, but a tester gives you this error
or is the inverter NOT producing power
how did you wire in the inverter
should be (2) wires direct to battery
and the inverter case ground goes to RV frame ground NOT to the battery
