shockoExplorerJun 02, 2017Inverter issuesHi, I bought a Thor 3000watt inverter , so I can plug my whip from my rv into it and power up the camper, so I don't have to run my generator. Its a 2016 work and play 34WRS. I have a Yamaha 6300...Show More
time2rollNomadJun 02, 2017Some inverters do not like the ground pin connected to the 12v negative. Try isolating the batteries and see if it works.Remove that white wire and anything else from the B- terminal and just have the inverter on there.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related ContentInverter Bad?Inverter installTowing lights issue12 Volt Power IssueElectrical outlet issues
