shockoExplorerJun 02, 2017Inverter issuesHi, I bought a Thor 3000watt inverter , so I can plug my whip from my rv into it and power up the camper, so I don't have to run my generator. Its a 2016 work and play 34WRS. I have a Yamaha 6300...Show More
shockoExplorerMay 04, 2018Ok,update on inverter issue.The thor 3000W will not work with my Rv wiring.I unhooked the batteries and still ground fault code.I bought a Traveller 3,000W Digital Power Inverter from tractor supply, I have to shut the converter breaker off, bingo, all 110 plugs work, no issue.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related ContentInverter Bad?Inverter installTowing lights issue12 Volt Power IssueElectrical outlet issues
