TobyRHudson's avatar
TobyRHudson
Inverter not inverting
I've got a Xantrex 1000W Pro Series inverter, hardwired into my RV, that stopped inverting after I changed out my coach battery. Was hoping for some input on solutions before I went out and bought a new one.
In my efforts to resolve the issue I've; 1) disconnected the power from the RV for over 2 hours and then hooked up the battery, 2) checked the GFI circuit to make sure it was working with shore power and was not tripped, 3)confirmed I'm getting pass through power when hooked up to shore power, 4)checked to be sure the breaker on the inverter was not tripped. The remote panel for the inverter shows it working with 12.6V input but no output.
Does anyone have any thoughts for anything else I can check. The inverter came with the coach in 2011 so it's roughly 4 years old.
  • HERE is a manual for 1000/1800
    Have you 'reset' inverter?
    DO you have any fault codes recorded?
    Battery not hooked up reversed cables?
  • Best WAG is that the transfer switch portion of the inverter is not operating correctly. It is stuck in the "pass through" stage.
    What I would try is this: With both the AC and DC power disconnected from the inverter (take the wires off the terminals), short across the AC terminals and the same for the DC terminals with a length of wire. That may be enough to disengage the transfer switch relay or any IC controllers.
    And that's + 12.6 and not -12.6?
    How are you checking for 'no output'?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
