thebig05ExplorerNov 21, 2017Inverter On or OffIf I'm plugged into a 30-50amp plug, does the inverter remote inside the camper need to be on or off? Hopefully an easy question. Any help would be appreciated.
wolfe10ExplorerNov 21, 2017If it is programmed as most inverter/chargers are, the question is:Do you want the inverter to supply circuits IF the shore power fails.On most, the charging and "pass-through" feature work whether the inverter is turned on or off.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
