If I'm plugged into a 30-50amp plug, does the inverter remote inside the camper need to be on or off? Hopefully an easy question. Any help would be appreciated.
Does the inverter charge the battery? You want the charging ON if equipped. The actual inverter can be ON or OFF depending on your preference or needs. I tend to leave stuff OFF unless needed.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
