KenS999's avatar
KenS999
Inverter Output Power Question
Hello,
If for example, an RV pure sine wave inverter is rated at 2,000W continuous output power and is equipped with three electrical outlets, would each individual outlet be limited to only 1/3 of the available 2000W or... can a single outlet draw the entire 2000 Watts of available output power, if the remaining two outlets are not used?
Thanks, Ken
  • KenS999 wrote:
    Thanks for the quick reply. So if I understand correctly... Each outlet is not relegated to 1/3 of the total power output? Is that correct? I would need to have that available 2000w to only one outlet, to run a microwave.
    Thanks, Ken
    Correct. You can run a microwave.
    I do.
    My inverter is wired so it can power all circuits in my electrical panel.
    Here's my installation video
  • a very few may combine three small inverters, which does limit the output per plug.
    None of mine do that.
  • I don't think that any outlets are made that are not capable of 15 amps(1800 watts) or more. If there is a single breaker or fuse on the output then the total would be available to any or all outlets. If there are 3 breakers or fuses then they might be divided equally.
  • Thanks for the quick reply. So if I understand correctly... Each outlet is not relegated to 1/3 of the total power output? Is that correct? I would need to have that available 2000w to only one outlet, to run a microwave.
    Thanks, Ken
  • Ratings are for all outlets combined so it doe not matter it you are using one or all three.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
