So you are using less than an amp at 110; you will use +-8 amps at 12 volts. But is the 88 watts AC just for the controls while running on GAS or are you going to use a 12 volt heat element? Seems to me a 12 volt heat element will draw more than 88 watts.
So more details would be helpful
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
