Canadian_Rainbi
Nov 03, 2015Explorer
Twomed wrote:
Remove the ground wire for 30 minutes. Like a hard re boot on you computer. If it is not a bad board, it will re set.
Certainly worth a try. It may also help to pull the 120v AC supply at the same time.
Had a similar problem with our Xantrex Prosine 2.0 years ago. The above reset it.
