Pops_R's avatar
Pops_R
Inverter Panel Stuck in Red Light Fault
I have a 2015 Thor Challenger and it has the Xantrex PRO XM 1800 Inverter.
For some reason the remote panel inside the Motor Home has stop working and only shows the red light fault and no error message just 3 red dash lines.
The Inverter can be heard running inside the compartment it is located in.
We have power, except when on the road we do not have power to the standard electrical plug next to the passenger seat and the USB connection on the dash does not work anymore while on the road. Not sure if those two things are related in any way to the malfunction of the Inverter panel or what.
So my question is how can I reset/ correct the non working Inverter panel or is it a situation that requires a certified technician to correct the problem?
I have tired pushing the 15A circuit breaker on the unit but it seems useless and there is no GFCI plug on the unit
  • If it's a 2015 model, it's surely still under warranty. While it might be a minor inconvenience, it will be well worth your time to take the unit to a dealer where these issues can be fixed.
    Is this an INverter or a CONverter? An INverter takes 12V power from the batteries and provides 120V AC power for household appliances. A CONverter is what takes 120V AC power from the power pedestal at the camp site, and turns it into 12V DC power to charge your batteries, and power your lights, water pump, detectors, refrigerator electronics, furnace, etc..
    If you have a CONverter, you will not have 120V AC power on the road.
    This is a big fancy 2015 Thor, so I'd imagine it does have an INverter and a CONverter.
